09-08-2020 07:59 AM - edited 01-05-2022 01:07 PM
I’ve been “locked out” of my self serve account. Any help would be appreciated. Thank you.
09-08-2020 08:17 AM
Thank you so much for your help. It’s appreciated.
09-08-2020 08:17 AM
Here’s when and how to contact the Moderator Team:
09-08-2020 08:16 AM
If you are locked out and you are not able to reset the password you won't be able to submit a ticket either. Can you try to reset the password again in about 1-2 hours from a different computer, Browser? Try using Incognito mode also clear cache/history before you try to reset the password. If you are still unable to reset it. You will need to give them a private message. Since you don't have access to your account.
You can contact them directly using (Private Message) this Moderator Team.
Make sure you enter a title and text in the body of the message describing the problem.
The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox. Keep an eye on your Mailbox.
Give them as many details are you can, Your phone number, pin number, email address, name on the account.
Please note: It may take 24-48 hours for them to get in touch with you.
Good luck!
09-08-2020 08:08 AM
@chris_p17 wrote:I’ve been “locked out” of my self serve account. Any help would be appreciated. Thank you.
@chris_p17 hi if you have tried the password reset without success contact a moderator click on the ? Bottom right hand corner Ask Simon to speak to a human this will help create a ticket to speak to a moderator say you want a password reset check the envelope top right corner for a reply response time is 2 to 48 hours
