02-27-2022 05:28 PM
When signing up my agent somehow entered a wrong password. Later, trying to sign in I got locked out of my account so I can't do the 'Forgot your password' procedure. Any suggestions for me? Thanks.
02-27-2022 06:27 PM
02-27-2022 05:39 PM
Hi hTideGnow,
Wow, thanks for your rapid and helpful response. I will try waiting an hour first. If that doesn't help, I will try to submit a ticket. Thanks again.
Terry
02-27-2022 05:34 PM - edited 02-27-2022 05:34 PM
Hi @terryinSA you waited an hour already? Usually it is just a temporary lock and it will be reset after an hour and you can try forgot password again
If still not able to reset, open ticket with PM CS Agent, Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
