Locked out of Account
manmohan
I am locked out of my account.  I tried a reset password but get the following message
Sorry, you've been locked out. Please contact Public Mobile for help.
gpixel
@manmohan
this tends to happen when you don't log in to your account frequently. the credentials are deleted for some reason.. I assume because of PM's 90 day inactive account deactivation linked to it. try to log in at least once, every 1-2 months to avoid the system forgetting your password
lourd
Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started.
just few hours ago I had same problem now I solved it. after take ticket you will need to wait for few hours for reply from them. check ur community mail box
pkaraa
msg here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
or click on the blurb on the bottom right and create a ticket.
Triguy
Try waiting an hour then try logging in again.
 Also try using a different browser and incognito mode.  Also try clearing your cache and cookies then reboot.
If you still need assistance then submit a ticket to a CSA.
@manmohan
Explain your issue to Contact Customer Support Agent by  ,
they can solve your issue, they are nice Service Team they will help you 100%.
 and they will Reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started.
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
         Good Luck...
