Locked Phone?
OF
When I first came to Public I had my own unlocked phone I purchased from my friend. The public SIM card worked, cause the phone was unlocked with their provider.  I sense got a new phone and gave my old phone (that was mine I didn't purchase through Public). They are going to use Lucky, when they put their new SIM card in it won't work, it says it's locked. They called Lucky and they said Public has it locked? Why? And now I need it unlocked! My understanding is if I own it you can't' lock it. Please resolve it.
darlicious
@OF
If the phone model was released before December 2017 then it's locked by the provider which in this case would have been either telus or koodo ( pm only started selling phones in November 2020). Contacting customer support to provide an unlocking code shouldn't be an issue. If the phone is a newer Samsung then contacting them via chat will have it unlocked as well within short order.
@OF
What make and model is your old phone?
If it is a Samsung, it has been locked by Samsung.
As for the locked SIM, normally it is not locked but reach out to a CS_Agent and see if they can help.
Meow
If you never used any other SIM but from PM you cannot be sure it was really unlocked. Similarly, if previous owner used it with any company owned by Telus, those other SIM most likely would work.
I know the case where phone locked to Rogers worked perfectly with Fido SIM.
Find out who was your friend's provider. Call them to unlock it. Or you can try talking with Samsung and if phone is Not international version (but pure Canadian) they should help you out.
Hi @OF
You said " I had my own unlocked phone I purchased from my friend", so you cannot confirm if the phone was originally from PM?  Maybe it is from Telus or Koodo?
If the phone was from Telus or Koodo, you still have a chance that PM CS Agent can help.  Open a ticket with them, Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1.  type: Contact CS Agent
  2. Click "Contact Us"
  3. Click "Other"
  4. Click "Click here to submit a ticket"
  5. you will then direct to another page to open ticket.
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
If it was a Samsung phone then that's a Samsung thing. Just chat with them and they'll unlock it. iirc it has to do with the first SIM inserted after unlocking. The phone saw your PM SIM after having been unlocked. Then it went ahead and locked to the new provider.
Samsung is very good with helping with that.
HALIMACS
@OF
It's possible your 'friend' gave you a phone that may have been previously locked to the TELUS network of companies. (including TELUS, Koodo, or Public Mobile)
If so, it won't work on any other mobile provider network, or their affiliates.
Contact CSA for help:
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
