03-09-2022 11:09 PM
Hi, Im locked out of my account so I cant submit a support ticket or renew my password. I have to update my payment because there was an autopay error.
03-09-2022 11:27 PM
Members have noted that their AutoPay was turned off for some reason. Check on the bottom of your account to see if you are currently registered for dynamic AutoPay.
If not, you will need to turn AutoPay back on.
03-09-2022 11:14 PM
03-09-2022 11:13 PM
The bot is not helpful but I will try the second method
03-09-2022 11:12 PM
The issue isnt loggin in, it from payment
03-09-2022 11:11 PM
You will be locked out entering the wrong password. Try again in 15 minutes then click on Forgot Password.
03-09-2022 11:11 PM
@Luz1 since you cannot reset your password, contact CSA for assistance.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
