Live in Canada, Travelling to US in August
terrif
Hi,
Travelling to the US in August.  Will my phone work there?  Curious!  Thanks!
Psygineer
Fun fact, when you cross into USA within an hour you should get a text from PM welcoming you to the USA and linking you to the US service package addon.
terrif
Thanks for the response!  The article does sum it up quite well.
will13am
@terrif, the following knowledge base article provides everything you need to know about US add-ons.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Plans-amp-Add-Ons/ta-p/250167
Dunkman
Yes, your phone will work if you had a US Roaming Plan.  Good for 10 days.  Cost varies from $8 to $20 depending on what you need.  Ie. text only, talk, data, combination of any of them..... Add it on with your self serve account.
