Leaving public mobile
08-12-2020 05:47 PM - edited 01-05-2022 12:46 PM
I’m going to leave public mobile, why can’t I find a live agent to speak to to resolve my issue.
Service
08-12-2020 07:03 PM
Sorry to hear you are leaving.
08-12-2020 05:49 PM
@Maryan86 everthing is online here. If you look at your previous post, I gave you the method to contact the moderators and some trouble shooting tips. The moderators are what passes as customer service for Public Mobile. There are 2 ways to contact the Moderator Team:
- Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
- Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
08-12-2020 05:49 PM - edited 08-12-2020 05:50 PM
@Maryan86 , what is your particular issue? Public Mobile support is done online via this portal. There is no call center. If you need to contact support, the moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.
