3 hours ago
I seem to be stuck in a loop
I tried to transfer a landline but now I can't log into my public mobile account until I enter a code received by SMS on the landline. That's not possible. I received this message from Public Mobile.
We’re so happy to have you with Public Mobile. All that’s left for you to do is transfer your number <***>******* over. |
There’s a 2-factor authentication process involved, so you’ll just need to respond to an authentication SMS sent by your previous provider. |
I can't log into my account without confirming my identity with a code received by SMS on my landline
How do I get out of this loop?
54m ago
@mh911 sometimes the resend code options have to be pressed between 4-5 times before you get the option for send code to email or call.
That means you would have to wait for the 4:42 minutes to fully expire first each time. Then select resend code again.
Annoying and time consuming yes.
How long has it been since you ported?
an hour ago
HI @mh911
click "Resend Code" there and see if email or voice call are there
2 hours ago
I unfortunaly don't have an option to select "didn't receive code" or "call me" on the page. the only option is enter the code or resend as shown below
3 hours ago - last edited 3 hours ago
HI @mh911
it takes 3 to 7 days for landline port. if you worry about previous provider sending you porting authorization text, then no worries. there is no such process with landline porting
yes, within this time, you won't get text and you cannot login My Account. You can try to click "Didn't receive code" and see if Send email is an option there, but I doubt it will work. But you can pick the call you for the code and it will call your landline with the code
3 hours ago
use this link to send a message to Customer Support. Give them as much acct info as you have..ie; acct number, ph number...etc..
