Which LG G7? G7 Thin? G7 One? G7 ThinQ
I have check all of them, it should work on PM without issue.
If yours is North American version it should work perfectly.
If yours is non North American, it will still work. Those non-NA versions, might not have all the channels PM uses, but still would work
