Koodo to resend SMS since dint reply in 90 minutes
SatsukiTakazak
I want Koodo to resend SMS. I couldn’t reply in 90 minutes so number hasn’t ported yet to public mobile.
Thanks for help
maximum_gato
@SatsukiTakazak
Check your private message box by clicking on your avatar at the top right corner of your screen.
HALIMACS
Ah, gee ...
That was deleted unnecessarily fast.
Hope you got it @SatsukiTakazak
@SatsukiTakazak Same number, I already sent you the number 🙂
SatsukiTakazak
do you know their number?
maximum_gato
@SatsukiTakazak
Just to confirm....you are porting from a koodo postpaid account? Have your koodo account # ready to give to the porting department. They close in half an hour so don't delay....
@SatsukiTakazak
I guess you are porting from Koodo to PM, There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
