09-06-2025 07:54 PM
I switched to public mobile from virgin 2 days ago and still don’t have texts and iMessage . I have data and calls but not texts . I can’t change my apn number either it won’t save . I have phone 12 pro max .
09-06-2025 08:34 PM
hi @Douglas88 you removed all old carrier sim and eSIM?
go to Settings, manually remove the phone number. Reboot phone and then go back and enter the phone number back. That would force iMessage to re-register
but if that does not help, ask PM support to check and refresh the account on the system
you can submit by direct message:
09-06-2025 08:24 PM
To fix iMessage after changing carriers, disable and re-enable iMessage and FaceTime in your settings, sign out of and back into your Apple ID under Messages settings, restart your phone, and check that your phone number is correctly registered.
09-06-2025 08:06 PM
Already did those things nothing worked .
09-06-2025 07:56 PM - edited 09-06-2025 07:57 PM
@Douglas88 wrote:I switched to public mobile from virgin 2 days ago and still don’t have texts and iMessage . I have data and calls but not texts . I can’t change my apn number either it won’t save . I have phone 12 pro max .
Hey @Douglas88
Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings and reboot.
Then if that doesn't work, go to Settings app, tap on Messages, and then toggle the iMessage switch to the off position. Reboot, go back and turn it on.
