New sim card
Phoneinfooran
Hello,
I got a new sim card and I want to keep my phone number. The steps provided by the chat bot are not usable as , apparently,  the procedure was disabled.
15 REPLIES 15
Phoneinfooran
I opened a ticket. I keep looking at the webpage, I got on the computer, and I don't see any of the sections mentioned. I don't see a profile either.
Thank you anyway:)
@BKNS27 wrote:
@Phoneinfooran
If you are on the PM app, at the bottom of the app. Go to the Account tab.
If you are online on your computer, the Account tab is on the left.
Click on it and it should be there.
On a computer, from what I can see, it doesn't say Account. It says Profile.
@Meow wrote:
Go to Profile and there:
- Change phone number
- Change SIM number
- Transfer Phone Number
The above information is out of date.  The current version of the My Account website doesn't say "change SIM card".  The option to change SIM cards is still in the Profile area,but is now under a subcategory of My Phone number.  Customers need to click on the pencil/edit icon in the SIM card section.
hi @Phoneinfooran
if you are going to use a computer to login My Account and update the sim card number, use this link
https://myaccount.publicmobile.ca/en/account/profile/change-sim-number
Phoneinfooran
Nothing. I'll probably have to go to a physical shop and fix it.
An agent was supposed to contact me here, right?
Nothing.
I'll get on the computer. Maybe it works from there.
HI @Phoneinfooran
if you are using the app, you can update the Sim card number at the Account page -> Change Your Sim Card
Phoneinfooran
Hi, OK,  I'll try. Many thanks for trying to help.
Phoneinfooran
I'm on my phone. Do I need to be on my computer to see all these features?
@Phoneinfooran wrote:
  • I don't see any of the categories listed above
HI @Phoneinfooran
if you cannot find where to update sim card, you can submit a ticket and ask PM support to help.   Submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
@Phoneinfooran
Phoneinfooran
Phoneinfooran
Logged in, but there is no section "Change Sim card". That's my issue.🙂
@Phoneinfooran
If you are an existing member of PM, just login to your account and go to Account tab>Change Your SIM Card.
If you are a new member that want to port your number over to PM, download the PM app and follow the prompts to step 6.
Meow
- Change SIM number
