10-31-2022 01:54 PM
My phone plan was just renewed today Oct 31, but the usage has already said my data was used up. Actually, I didn't use any. In addition, I didn't call even one minute today, but the usage said I already used 14 mins. Please double-check the accuracy of my plan usage.
10-31-2022 01:59 PM
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh. Click on little spinner refresh icons lower down.
10-31-2022 01:56 PM - edited 10-31-2022 01:59 PM
If you called your voicemail or check for messages, that uses up your minutes on the $15 plan.
Sometimes there's a glitch and your usages don't get reset after your renewal.
10-31-2022 01:55 PM
HI @anniezhang512 just a site cache issue, everyone is complaining
Clear cache and relaunch browser
or use Private mode/Incognito mode to login
or use a new browser to login
With one of the 3 ways above, you will see the correct usage
10-31-2022 01:55 PM - edited 10-31-2022 01:55 PM
Can you clear your browser cache and history and then go incognito/private mode. Also click on the spinner icon to update information in self service.
