07-03-2017 10:14 PM - edited 01-04-2022 02:17 PM
Hi, I just switched to Public Mobile a few minutes ago.
I chose the following plan and had my number ported:
Plan Length: 90 Days
Unlimited Talk: Canada Wide
Unlimited Text: Global
Data: 6GB/90 Days
Autorecurring every month.
(So $135/90 days - $2/mo)
Now I believe my number ported fine however I can't make any phone calls or use data (have not tried text yet). When I go to self serve I see that it says my plan is:
And I $127.00 in available funds at the top. So it seems I have nothing in my plan. If I wanted to add those same features I already paid for I would have to spend another $8.00 to add them because it seems it just activated the SIM Card for $8 already.
Really need some help getting this sorted.
07-03-2017 11:38 PM
@PatrickM wrote:Thanks for the replies. I sent a PM to a moderator, hopefully this gets resolved soon as this is my only phone. And since I ported my number from Bell that account has been cancelled so I can't just pop that SIM card in and have service in the mean time. Kind of a rough start for sure.
You can for now use Fongo.com to make and receive temporary calls with WiFi, until everything is fixed for you.
07-03-2017 11:23 PM
07-03-2017 11:22 PM
07-03-2017 11:17 PM - edited 07-03-2017 11:19 PM
The activation process is really broken these days. There are many reporting that the plan selected is not the plan after activation. As mentioned already, contacting a moderator is needed to resolve the account problem. Be patient, the backlog is 2 to 3 days.
07-03-2017 10:33 PM
