2 hours ago
2 hours ago
Did you reply to the text with YES confirming you are porting over to PM within the 90 minutes window with the Virgin SIM in your phone?
If not, you will need to contact a CS_Agent restart the porting process for you.
2 hours ago
if you cannot even make calls, it is a sim/account provisioning issue. Easy fix for PM support but just need to engage them by direct message here
