03-17-2023 01:06 AM - last edited on 03-17-2023 01:08 AM by computergeek541
Hello,
I'm trying to move a friend's Koodo number over to a Public Mobile SIM, but it just spins forever.
I decided to just create a new number instead. It is currently spinning also. I'm not sure how long it will take.
For some reason, when I try to verify his new account, I never receive the verification email from Publicmobile.
I can send emails to him from my email, but after multiple tries, I don't receive the code sent to the same email address from PM.
I am not able to receive phone calls/texts to the old number. It seems to be deactivated for some reason.
Will this cause a problem?
Does anyone know of an issue with security codes not sending?
I'm in a private window btw.
03-17-2023 04:34 PM
Hi and thanks for your response.. I tried to port it for hours but no go.. just spinning around and around so I just cancelled it today.. Set up a new number instead. I'd like to move his old number over but the old number is not active so I can't receive texts or calls...
03-17-2023 07:59 AM
@boogeyman - was the koodo account still acive?
Was this a prepaid or postpaid account, regardless of this, you said you created a new number instead. So in that case customer support can help with porting.
You may also submit a ticket with Public Mobile representatives (CSA) for help; click this link for issues with transfer/porting of phone numbers over to Public Mobile.
03-17-2023 05:55 AM
I will send you a phone number you can call for porting assistance.
In order to get that number, check your private message mailbox by tapping the envelope icon upper right.
03-17-2023 01:22 AM
Good thing your friend had a Koodo account. It would can be fixed by a CS_Agent.
Your friend will need contact them in the morning since agents are available from 6:00am to 10:00pm EST.
Best to have their Koodo account number handy with in contact with an agent.
03-17-2023 01:13 AM
Does anything still work on the Koodo service? Also, was the porting request to Koodo ever submitted? Although porting out from Koodo should have required your friend to reply to a text message from Koodo to approve the transfer, I'm wondering if the nubmer porting may have arleady been completed.
@boogeyman wrote:Hello,
