June 6 promotion for referee
GJR
I refered a customer with my # and I didn't received my $5  for 5 months
darlicious
@GJR
You can only track your referrals if you are on the $$ rewards program. You have no way of tracking referrals if you are a points program customer. Did you recieve the Cha-ching text the following day? Did your referral recieve the $10 bonus referral credit? Did they recieve the first $5 RAF credit on Friday June 10th? If possible reach out to your referral first to see if they used your referral code and if they recieved any of their associated RAF credits. With any kind of proof that you made the referral and they activated during the eligibility period you can then ask customer support to open a tech team ticket to find out why it hasn't been applied.
My referral and I are still waiting for ours to be applied....28 days later!🤔
dust2dust
So the friend signed up on or before June 6th? Do you see their last 4 digits in your refer a friend listings? Do you see the extra $1 or point on the rewards page?
RossN
@GJR Please remove your referral number it is not allowed on this Website click the little down arrow top right of your post to delete the number
JL9
Was the right code used without typos and it was done within the promotional period? If so you should have received the text about referring someone.
Your friend can reach out to a CSA to investigate to see if there was an error so they can add it manually
CountyDownIeUk
TOS requires to remove your referral code.
@GJR   Please remove your referral code.  You are not supposed to post the code here for any reason
This is a referral bonus that both sides get it.  So, for referral issue, have the referee, the one wo just activated , to open a single ticket with PM Support for both of you.
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
