Joining public
Brushett
Hi everyone, my friend who is joining public is not receiving there final text to confirm there identity and complete the process
Hi @Brushett
So, if you're porting your number from another provider, once you initiate the port on the Public Mobile side, you will receive a text from Bell asking permission to port the number. You must say yes. But I take it a step further by watching and making sure the Bell name is removed from the top of your phone and then test make a call. If the call fails, you know the port worked. Did you get a text from Bell?
Brushett
Yes from bell, will they need to unlock?
JRod
Hello! @Brushett
Are you referring to the two factor authentication? What step are they on of the signup process?
Are they porting a number or getting a new one from public mobile?
Have they already paid for the subscription?
Are they using the app to signup or the desktop site? If the desktop site please have them try it on the app.
@Brushett ask your friend to put the  sim in a phone and see if it connects
 And try make outgoing calls and check if incoming calls work
if not, message support for further assistance
@Brushett  Try tapping resend code a few times or if there’s an option that says didn’t get code tap it and you should then be presented with option to send code to email instead . You can also try the reset password option too . And try on the app instead of website . If issues or persists please submit ticket with support to help
private message   To CS_Agents click
Chalupa_Batman
Hi @Brushett Are they porting from another service provider?
