Esim failed
Vantage
I deleted it on my phone, and now I need a new one to activate my new subscription
Vantage
Thanks for the info..everything is working perfectly!!!
@Vantage if you installed the original eSIM and deleted it, you will have to re-buy a new one using the app
First, download the app, click circle with a + from the bottom left to bring up the menu and go to Subscription & Add-on page, scroll down to the bottom and click Shop SIM Card Now.  You can buy and install eSIM from there
@Vantage  You can request a new one for $5 from support
private message   To CS_Agents click
