09-18-2020 11:26 AM - edited 01-05-2022 01:15 PM
Hello,
The number I requested was deactivated prior to the port. How can I get a different number assigned?
09-18-2020 11:40 AM
@zoiab wrote:They cannot reactive it without restarting the service and sending equipment over. I would like to get a new number assigned today since the service has not been functioning properly for a few weeks now.
So you're abandoning it then. Ok. Change number it is. You can only port numbers from an active service.
09-18-2020 11:36 AM
09-18-2020 11:34 AM
You can port with a temporary number then change your phone number in your self serve account.
09-18-2020 11:32 AM
@zoiab wrote:Hello,
I'm interpreting a little confusion. Was the number yours from a previous provider? Would it be a problem to reactivate it and then before the end of that term to port it over to here?
You can always use the Change Number function in the self-serve though. You can do that once every 30 days.
09-18-2020 11:31 AM
@zoiab wrote:Hello,
In self service you can change your number every 30 days.
