09-22-2022 12:14 AM - last edited on 09-22-2022 01:00 AM by computergeek541
09-22-2022 12:32 PM - edited 09-22-2022 12:34 PM
09-22-2022 12:24 PM
@BKNS27 not sure if you noticed, but the OP mentioned it's been 5 days already. I'm reasonably certain that 120 hours is still >= 72 hours....
09-22-2022 12:54 AM - edited 09-22-2022 12:34 PM
You will see the $10 credit in your account in 72 hours.
There are requirements for the 2gb for 12 months…minimum $25 plan and active your SIM before August 31.
If you meet both requirements, again it will show up in 72 hours.
Please contact a CS_Agent to look into it for you by private messaging above or create a ticket on SIMon Chatbot below.
09-22-2022 12:23 AM
open ticket with PM support and ask them to check it out for you.
At https://publicmobile.ca/chatbot.
Start by typing "Submit a ticket", then click "Contact Us", Then click "Other", then click "Click here to submit a ticket
have trouble with Chatbot: Private message CS_Agent
