06-18-2018 12:19 AM - edited 01-05-2022 04:56 AM
06-18-2018 04:16 AM - edited 06-18-2018 04:35 AM
@pm-smayer97 wrote:I sometimes find more than one answer makes up the WHOLE solution.
In those cases, perhaps it's best to simply bravo each component of the solution and give credit where it's due in a detailed explanation. If you really want to mark a solution but want to give relatively equal credit in terms of contribution calculus, you could mark the closest one as solution and give the other members a few more bravos for their other posts elsewhere.
06-18-2018 01:01 AM
@meocon wrote:@pm-smayer97 you can choose which solution is the best answer for your question.
Thanks but sometimes NO ONE answer is complete and more than one answer are correct to make up the COMPLETE and CORRECT answer...
06-18-2018 12:52 AM
06-18-2018 12:23 AM
