Is it 3 Mbps or 2.5 Mbps?
zxcvbnm
Two screenshots. The first is from the Terms and Conditions section of the Plans page (https://publicmobile.ca/en/on/plans) and the second is from the More Details section of the Change My Base Plan page in Self Serve (https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/ChangePlanLandingPage/, then click Change Plan).
I've highlighted a few discrepancies, but the big one is that the Plans page says 3G plans are throttled to 3 Mbps, while the Change My Base Plan page says they're throttled to 2.5 Mbps.
Which is true? A 0.5 Mbps difference may not seem like a big deal, but at these low speeds, it is.
Did this change at one point and they forgot to update one of these pages?
Is this portending a change that's about to come?
2 REPLIES 2
NDesai
@zxcvbnm It used to be 2.5Mbps when it first launched. Then Lucky/Chatr came up with 3Mbps speed. So PM ended up bumping the speed up to 3Mbps, but never bothered to change this speed everywhere Smiley Sad
@zxcvbnm
The maximum speed for the customer while connected to the LTE network on a "3g" plan is 3Mbps.  Please ignore any information that says otherwise as it is outdated.
