03-12-2024 09:58 PM
I just noticed this right now... as I currently know my *611 PIN number but for others, do you have it?
Can you confirm that it is gone / broken?
Desktop:
Mobile App iOS 17.4 V2.1
03-12-2024 11:01 PM
I do not have the option anywhere. Luckily I used the link provided which worked. Thank you for that.
03-12-2024 10:36 PM
For myself on the app: Select Account tab, Reset PIN Number.
I am not sure if everyone has that on their app though. Sorry.
03-12-2024 10:22 PM
@softech - Yes, thanks for the info! I just logged into my older account and it shows up!
Also, thanks for the direct link!
The app also doesn't show up the PIN option, but the direct link will do!
03-12-2024 10:18 PM
for some reason, the PIN update section is not shown for new accounts
Check again with the new app 2.0, maybe it shows there
if not, use the browser and use this direct link
