08-03-2015 02:40 PM - edited 01-04-2022 12:41 PM
Hello,
Someone knows if the LG A275 is compatible with pm's network?
http://www.amazon.com/LG-A275-Black-Unlocked-QuadBand/dp/B009IRGQPO/
Thanks!
Daniel
08-03-2015 07:39 PM
You could try www.canadagsm.ca. They are quite clear which carriers can be used with each phone.
I have not bought from them because I usually scrounge free cast offs from friends for my 'emergency' backup phone. For use on Public Mobile I get someone's old Telus or Koodo phone.
Currently the cheapest new phone from TELUS/Koodo is an Alcatel A392A $70 flip phone; no one seems to be carrying the little bar phones.
Good luck in your hunt.
08-03-2015 07:11 PM - edited 08-03-2015 07:11 PM
08-03-2015 06:35 PM
Hi. I checked if that LG A275 phone is Comparable
Answer, NO
PM requires Handsets with 3G 850/1900 MHZ as Bare Minimum for Service
08-03-2015 04:05 PM
Check out Telus and Koodo for pre-paid, or pre-owned, phones. I understand all Telus/Koodo phones work on Public Mobile. The price seems to be $60-$100. Some are "smartphones" but you can still use them just for Talk, and when you are near a wifi location surf the web for free as well.
Consider texting as well as it only adds $5/30 days. My sister never had a cell phone until 2 years ago when she jumped in with both feet and now texts more than 10/day! 🙂
08-03-2015 03:55 PM - edited 08-03-2015 04:11 PM
Thanks guys. Will keep looking.
Anyone has a suggestion for a simple bar phone that would work? I don't want it to be a smartphone.
Is just a backup phone.
Thanks again,
Daniel
08-03-2015 03:37 PM
OK Thanks I see that button now.
08-03-2015 03:34 PM
08-03-2015 03:20 PM
Sorry the post I quoted was from Lachlan_M
08-03-2015 03:19 PM
I don't think the LG A275 will function because it seem to be only a 2G phone. You need at least 3G.
Public Mobile is owned by Telus. To get a new smartphone that will work on Public Mobile, you have to purchase a phone unlocked or locked to Telus/Koodo.
I suggest you Telus (online only), Apple, Google Nexus, Microsoft, Staples, Best buy, Costco and Walmart
Telus/Koodo/Public Mobile frequency are :
3G UMTS/HSDPA = (850MHz / 1900MHz)
4G LTE Band 4 = (2100MHz / 1700MHz)
4G LTE-Advanced = 700MHz (LTE-A not yet launched by Telus/Bell)
08-03-2015 03:18 PM
@Lachman wrote
01-05-2015 04:24 PM - last edited on 04-16-2015 02:44 PM by Moid_I ![]()
Public Mobile works on following frequencies:
Which means most of the 3G,4G HSPA/ LTE phones that are compatible with these frequencies will work on Public Mobile. If your phone is locked to specific carrier, you’ll have to get it unlocked.
Phones compatible with Telus, Koodo, Bell, Virgin will work on Public Mobile network. All 3G, 4G phones from Rogers, Fido and ChatR are compatible and will work on the Public Mobile network.
To verify if you phone will work on Public Mobile network click here
