12-02-2024
09:30 PM
12-02-2024
09:44 PM
Dunkman
I am thinking of switching to PM $35 plan. Offer details state "$10 bill credit per month will be applied to your account for 6 months. Applicable only to plans $45 and up. Bill credit will be removed upon rate plan change."
Does this mean that this plan is usually $45 and I will be paying $35 for 6 months and it will switch to $45 after?
12-02-2024 09:35 PM - edited 12-02-2024 09:36 PM
@ivand YES The $10 for 6 months is only for the $45 -$55 plans . The $35 plan doesn’t get that promo . So if you don’t need more then 50GB best to just go for the $35 plan and it will remain that price even after 6 months and continue until you decide to change plans . Going with $45-$55 plan you will get the $10 off but only for 6 months and it’s harder to down grade plan price so best to start lower price that fits your needs and if you find you need more data only then upgrade plan price
