12-07-2020 10:03 PM - edited 01-05-2022 04:24 PM
Hi, I tried to set up the hotspot function on my iphone 6, when i clicked the hotspot section, it says if I wanted to set up the hotspot, I needed to contact public mobile. When I clicked the APN section, it only has three lines: APN, username and password, the APN line is sp.mb.com and the other two are blank.
I want to use mobile data on my computer, is there a way I can make this work? Thanks!
12-08-2020 04:58 PM
Good to hear that.
Everything went smooth..
12-08-2020
04:54 PM
12-18-2020
04:25 PM
Luddite
Ok problem solved! I reset my Network settings and restored them to factory default and now it works! Thanks everyone
[OK ..... Luddite]
12-08-2020 04:48 PM
@Olivia2021 wrote:I can browse internet on my phone using data, just cannot create hotspot ....
... and wifi off? Just in case you're actually connecting to a wifi.
Do you get that message on your phone or the connecting device?
12-08-2020 04:41 PM
12-08-2020 04:40 PM
@Olivia2021 wrote:Yes, I tried this, but when I turned the mobile data on and tapped the personal hotspot, it asked me to contact public mobile if I want to use it.
Are you otherwise able to go to web pages on your phone without wifi and without hotspot? Maybe you're out of data.
12-08-2020 04:29 PM
12-07-2020 10:43 PM - edited 12-07-2020 10:44 PM
Here is the APN Setting
Then settings => cellular => turn switch on => personal hotspot => tap => switch on Allow others to join => enter a password (unless you want every one in Starbucks use up your data)
Then the other device has to find your Hot Spot. Your Hot Spot name will be in Settings => general => about => then what ever is in the name field.
12-07-2020 10:34 PM
Here are a couple of threads on this issue by our resident Apple guru CalgaryBen
12-07-2020 10:07 PM
Does hotspot work if you use isp.mb.com instead?
