07-06-2019 04:57 PM - edited 01-05-2022 05:45 AM
I recently picked up an iphone 6. It was previously used with Telus. My current phone is working without a problem with the current sim card. When I put the sim card into the iphone it says "searching" or "no service".
I've looked through the community messages and have seen similar concerns along with some things to try. The phone has the lates IOS, I've tried toggling airplane mode on and off, toggled roaming and LTE, nothing works. Does anybody have any thoughts on how this can be fixed?
07-06-2019 06:33 PM
@Ashbury wrote:Yeah, not stolen. I completely trust the person I got it from. We've been friends for years and wouldn't even think getting a second hand phone. He's all about getting his tech off the shelf. 🙂
Yeah, unfortunately it can be done, by other people, not necessarily the person you bought it from, good idea to check!
07-06-2019 06:31 PM
07-06-2019 06:30 PM - edited 07-06-2019 06:32 PM
@krazykiwi wrote:
@Ashbury wrote:green for valid purchase date, expired on the other two.
did the IMEI check out?
07-06-2019 06:23 PM
07-06-2019 06:23 PM
@hairbag1 wrote:Did you check to see if your phone has been flagged as stolen ? Click the Get Started tab at the top of the pages, then scroll down to Start Checking. There's a place to see if that phone has been reported as Lost or Stolen.
Hope it's not that...but good luck.
That is the website I just sent him too!
07-06-2019 06:22 PM
07-06-2019 06:22 PM
07-06-2019 06:18 PM - edited 07-06-2019 06:18 PM
@Ashbury and here with your IMEI number
07-06-2019 06:17 PM
What do you get when you put the serial number in here?
07-06-2019 06:15 PM
@Ashbury wrote:I received it fully reset but I figured I might as well do it again via ITunes. I just finished a full reset about half an hour ago.
Yes the APN was what I was looking for and it is correct. And I am assuming that it is still not working after you did the full reset?
07-06-2019 06:09 PM - edited 07-06-2019 06:13 PM
07-06-2019 06:08 PM
there's the APN: isp.mb.com
07-06-2019 06:07 PM
Did you try a full reset of the phone just to start out fresh to see?
07-06-2019 06:03 PM
@Ashbury wrote:And if it means anything, the phone is showing that it can read the sim card as it says Public Mobile in the carrier settings.
I assume you mean it says Public Mobile after "Network Selection"? What does it say for Celluar Data Network?
07-06-2019 05:57 PM
07-06-2019 05:54 PM
The sim works fine in my other phone.
07-06-2019 05:53 PM
@Ashbury confirm that the sim you are using is a sim you used in another phone and it was working properly?
07-06-2019 05:51 PM - edited 07-06-2019 05:54 PM
@Ashbury on a side note I would get it unlocked just to avoid hazzles in the future.
UPDATE - second thought, get it unlocked now if you can, then you can use the fido sims to help troubleshoot this issue.
07-06-2019 05:50 PM
@Ashbury wrote:Nope. But the phone said that it wouldn't. I didn't think that the phone was locked but perhaps it is. Either way, it shouldn't matter because PM is Telus.
Yes, just asked because if they did work that means the phone is not locked and it is not a phone problem.
07-06-2019 05:48 PM
07-06-2019 05:45 PM
@Ashbury wrote:I've reset the network settings as well restarted. I hooked it up to itunes and it said that couldn't verify the sim card and suggested that I pull the sim card out and put it back in, remove the sim pin (which I'm not using). I'm not new to iphones but this one is stumping me. It's possible that there is a hardware problem but I can't verify that as all the other sim cards in the house or Fido.
Does the FIDO cards work?
07-06-2019 05:44 PM
07-06-2019 05:43 PM
@Alex888 wrote:
@AshburyIs your phone locked to Telus? You may need to contact them to get it unlocked.
AHHH what?!?!?!? @Alex888 , you have been around long enough to know that Telus and PM are the same company on the same network so having a phone locked to Telus will still work on PM.
07-06-2019 05:15 PM - edited 07-06-2019 05:17 PM
I assume the 6 is basically the same as the 6s. Also Someone with an old 4 was having the same issue last night and hooking to iTunes via usb fixed their issue I believe
07-06-2019 05:13 PM - edited 07-06-2019 05:14 PM
07-06-2019 05:09 PM - edited 07-06-2019 05:11 PM
@Ashbury wrote:I recently picked up an iphone 6. It was previously used with Telus. My current phone is working without a problem with the current sim card. When I put the sim card into the iphone it says "searching" or "no service".
What @GR suggest may work. I would also do a "all settings reset" as well if you have not done that.
07-06-2019 05:05 PM - edited 07-06-2019 05:07 PM
07-06-2019 05:01 PM
07-06-2019 04:59 PM
Maybe do a network reset and try the Sim again. My daughter has an iPhone 6 on public mobile with no problems!
