Phone brand
DSteele
I own a lg g6. I am wondering if it is compatible with public mobile network?
popping
LG G6 should work with PM.
You need to do a network reset on your LG G6 after switching provider in order to get your data working with the new provider.
Triguy
It should be compatible with PM.
3G bandsHSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G bandsLTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 12(700), 13(700), 17(700), 20(800), 28(700), 38(2600), 40(2300)
bravo_md
YES it is I have the same phone . It's great.
