Text bubbles are green
Johnb92
Text bubbles are now green on iphone, they were blue to start, just started using this today. is this because of the current service upgrade?
@Johnb92
The sender must have enabled RCS Messaging on their iPhone.
That is what I have done because RCS gives a higher resolution photos and videos.
hi @Johnb92
can be a problem on the other end too
did you get green for all your iMessage contacts?  your mobile data or wifi are working?
try reboot phone, try turn off iMessage, wait 5 mins and turn it back on
umnikke8
If you changed phone numbers or providers you might need to logout and back into iMessage and your Apple account. Try disabling iMessage, logging out of Apple account, log back in and turn iMessage back on. Make sure it's showing the proper phone number.
Johnb92
Ok but nothing was changed in settings or anywhere else, why are they not being sent via imessage?
hi @Johnb92
If you see a green message bubble instead of a blue one, then that message was sent using RCS or MMS/SMS instead of iMessage.
