11-21-2021 04:57 PM - edited 01-04-2022 05:08 AM
Will the iphone 13pro work with the public mobile service?
11-26-2021 10:31 PM - edited 11-27-2021 06:44 PM
The same question always gets asked each time a new iPhone model hits the market.
And the same answer always applies:
Public Mobile is compatible with all iPhones. (Those submodels specifically intended for US/CA/NA or "Global" regions. Not those purchased through other channels which are specifically intended work only in other regions like Europe, India, Asia, etc.)
But not all iPhones are compatible with anything other than the network and provider which sells them to consumers. There are sometimes compatibility locks and limits and problems but they are not caused by Public Mobile and they are not caused by Apple. The Big Three still have ways of "carrier-locking" their devices and subscribers in practice - and their point-of-sales people will always claim none of their devices are locked - even though these practice are legally disallowed by CRTC Wireless Code.
11-26-2021 08:55 PM - edited 11-27-2021 02:33 PM
So I guess it takes 7 replies of yes to be convinced. Lesson learned or of course they just select the last correct entry. More encouragement for repetitive replies.
11-21-2021 09:43 PM
11-21-2021 06:35 PM
@esjliv wrote:
@magnolia223 wrote:Will the iphone 13pro work with the public mobile service?
If you are not convinced yet...
If not convinced.. best to do is.. Buy one and test it out.. LoL
11-21-2021 06:34 PM - edited 11-21-2021 06:42 PM
https://www.kimovil.com/en/frequency-checker/CA
Apple iPhone 13 Pro = all green means Go, Yes compatible.
11-21-2021 06:23 PM
With worldwide distribution of devices, it's always a good idea to ensure the device one is acquiring is intended for the North American market.
Virtually any device sold for use in North America will be compatible on the Public Mobile network.
One way you might want to 'test' this is to borrow an active SIM from friend/family who may also be on the PM network and place it in the device - if you can text & call (in and out), you're good to go!!!
11-21-2021 06:16 PM
Any LTE compatible phone manufactured for North American markets should 100% work on Public Mobile.
You may have to double check whether it is compatible if you buy or bring an phone from overseas.
11-21-2021 06:13 PM - edited 11-21-2021 06:14 PM
If the first 2 replies don't convince you surely the second two will....or any of the ones that follow.....
11-21-2021 06:09 PM
It is compatiable with PM.
11-21-2021 06:08 PM
Yes, good news is that all iPhone will work on this network without issue.
Make sure you have the latest Carrier Profile downloaded.
11-21-2021 05:01 PM - edited 11-21-2021 06:44 PM
@magnolia223 Yes it's compatible
Edit: Only caveat is, if you buy it used, be sure to check it's not blacklisted:
11-21-2021 04:59 PM - edited 11-21-2021 05:00 PM
Yes is will working with Public Mobile 100%..
visit Here link to you can check it full information about your device.
Public Mobile uses the following frequency bands:
