05-26-2026 06:30 AM
My husband and i have been having trouble with cellular data. I have an iphone and he has an andriod. Yesterday we both could not get on the internet or use any aps. And the same this is happening today. Turned off and on airplane mode as well as the cellular data. Works for a few minutes and then cuts out.
Any ideas????
Thanks
05-26-2026 06:47 PM
Try toggling airplane mode see if that will fix. Lots of people with same issue this seems to work for most.
05-26-2026 06:41 PM
Can call and send texts. Have no data and cant receive photo messages
05-26-2026 06:37 PM
Make sure to remove or disable any previous SIM if you have one and turn on or make the Public Mobile eSIM primary if one. Then reboot and try again.
05-26-2026 06:31 PM
Just activated my new number.
Can make outgoing calls however CAN NOT received incoming calls. Wow.
05-26-2026 06:30 PM
no i’m in nova scotia
05-26-2026 06:02 PM
PM is having some internet trouble in some area. Try to Reboot the phone and Reset network settings
05-26-2026 06:01 PM
Try Reboot the phone and Reset network settings
05-26-2026 06:00 PM
Following resetting the network, rebooting my phone and turning airplane mode on and off, I now have data back!
05-26-2026 05:54 PM
I am having the same issue - in Nova Scotia
05-26-2026 05:51 PM
hi @MarleyMoo and @arronmoore
there seems to be problem with Mobile data in some area. Try Reboot phone and click Reset network settings
if you need to submit ticket, you can use Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
05-26-2026 05:49 PM
Apparently there's a way to submit a ticket but I'm not sure how
05-26-2026 05:45 PM
Same here wish I could talk to customer support about it
05-26-2026 05:43 PM
For no apparent reason my data has stopped working. I haven't got anywhere near my limit and I've checked all my settings and nothing has changed. Any help would be appreciated!
05-26-2026 05:38 PM
Are you in Ontario? Public Mobile is experiencing some service issues now and mobile data might not be stable until the issue is fully resolved. In the meantime, Reboot your phone every once in a while
05-26-2026 05:34 PM
I have service and full bars but my data randomly goes away. It won’t say lte or anything. it works when i turn my phone fully off and back on but just wondering if there’s a quicker way so I don’t have to do that 10 times a day.
05-26-2026 05:28 PM
I've lost data in Ontario today. Still have lots of data available, talk and text work fine.
05-26-2026 05:20 PM
I had been using it without any problems, but since yesterday, my internet connection keeps disconnecting
When I turn my phone off and on again, it connects for a short time, but then it disconnects again. This keeps happening repeatedly.
What should I do?
05-26-2026 05:10 PM
I am not getting internet in my mobile since yesterday. However I am able to make call only internet is not there. I recently opt to upgrade the plan which will be applicable from tomorrow. is that somthing impacting my mobile internet.
05-26-2026 04:48 PM
It appear that there is an issue. For now, they airplane mode on and off.
05-26-2026 04:45 PM
I had tried this , it had work temporarily; then down again.
05-26-2026 04:42 PM
I can’t access my cell service- no phone calls and can’t use data. Is there an issue with the system? Living in NB
05-26-2026 04:39 PM
many of this problem today. Reboot phone and reset network settings would make it works again
05-26-2026 04:39 PM
@Flinstone wrote:My cellular data just stopped working. All settings on my phone are ok.
05-26-2026 04:38 PM
05-26-2026 04:37 PM
05-26-2026 04:15 PM
hi @Cvark
are they in Ontario?
PM has been having some data issues for some subscribers, so, it likely you are just part of those affected.
Try Reboot phone and Reset network settings when needed
if you like, report that to PM support agent as well. Submit a ticket with CS Agent using Chatbot here:
05-26-2026 04:13 PM
Starting 2 days ago noticed data drops on mine and my partner's seperate plans. They are active. Have tried resetting network powering off phones.toggling between airplane mode sometimes helps.
05-26-2026 03:46 PM
I'm in Midland and am also having issues as of yesterday, rebooting my phone no longer works 😞
05-26-2026 03:41 PM
Same happened here in Saint-Laurent (Montreal, QC) since yesterday. No data network connection, only voice on 3G network. Phone is usually connected to LTE+ or LTE networks. Just rebooted the phone as suggested and now it seems that LTE+ has come back on.
05-26-2026 02:59 PM
If you have a physical SIM card testing in another phone.
You could also reset your phone networks to see if that will help.
If no success message support for assistance.
