Internet access
Edwin3
Hello, I have plenty of data but can't add access the internet or LTE when away on from home.  Any idea on how to access the internet,?
acdcmj
I had problems with my data a couple of days ago.  It seemed to be ok the next morning but I had to power off my iphone & start it up again for the data to work.  Try shutting off your phone & turning it on again to see if your data works.
@Edwin3 wrote:
Sorry I messed by accepting as solution.
I have an I-phone.
How do I updat ethe Carrier Profile?
Hi @Edwin3
For carrier update:
1. Make sure your iPhone is connected to a Wi-Fi or cellular network.
2. Open your phone's Settings app, tap General, and then tap About.
3. Scroll down to Carrier. Next to Carrier, if a new update is available, you'll see an option to perform this update. Otherwise, you'll simply be shown the currently installed settings or carrier version number.
@Edwin3   no worry, you can go back and click Not the solution
For carrier update
Tap Settings > General > About.
Follow the onscreen instructions to install your carrier update.
and an important question, did data with PM network ever work on your phone??
Edwin3
I have an I-phone.
@Edwin3   Your data ever work before?  It just stopped working or it never work?
What kind of phone is that ? brand and model?
if it is an iPhone , check Carrier profile, make sure it is updated
if it is Android, it  could be APN.  But start with clicking Reset all networks
HI @Edwin3   make sure mobile data is turned on
