03-09-2024 02:49 PM
Hey,
I currently have 1 gb data and looks like additional unused bonus 1 gb data which says in red 11/30 left - what does this mean?
03-09-2024 03:52 PM
@jstyles1 The bonus data (like that from Christmas 2022) is not supposed to expire. Could it be the 1GB that came with your plan ($25) or an add on that you recently purchased?
03-09-2024 03:18 PM
As of few months ago data add-on have limited life of only 30 days. So you have 11 days left to use your data add-on. If you do not use it they will expire at next renewal.
03-09-2024 03:15 PM
That bonus data was only available to be used for 30 days.. You have 11 days left to use it.. I have 8 days left to use mine..
03-09-2024 02:52 PM - edited 03-09-2024 03:17 PM
Red usually means that the account is suspended or data about finished. If you log out and log back in, does it still show same?
03-09-2024 02:51 PM
@jstyles1 : Would you be able to share a screenshot. That most probably means that the bonus data is almost finished but I can only understand properly if I could get some more information; so if you could share a screenshot of that portion of the screen it would be helpful.
