Incorrect ESN/MEID
ThePolishMike
Hello I am looking for the porting phone number please, I had this error earlier. Thanks.
ThePolishMike
@softech Thank you so much for the quick reply! Much appreciated!
WongoBongoooooo
I got the same error with the port in for my number.
The text message I got said someone would contact me, I haven't been contacted yet.
The chatbot has advised that there is a technical issue, I'm guessing that the two are related.
@ThePolishMike
it is better to provide them account number from the old provider instead of IMEI.  Please get the account number first.  Then, there is a number to call to talk to live support and update them the new info,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
