08-28-2023
09:21 AM
08-28-2023
04:00 PM
computergeek541
Couldn’t get the transfer done, got a message from PM yesterday said someone will contact me shortly, still not happen, what should I do.
08-28-2023 12:17 PM
Thank you, I'm on hold for an agent now.
08-28-2023 12:07 PM
sent, please check your Community inbox
08-28-2023 12:01 PM
I am having the same issue, could you send me the number as well please?
08-28-2023 09:33 AM
I got similar message. If you have any active Sim, turn it off. Your phone may allow only one active esim.
after I turned off other esim, the activation continue. It gave me instruction to reboot the phone to complete activation. And it works.
08-28-2023 09:22 AM
@AlanZh actually, they might not contact you quick enough, better for you to reach out to them
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
