06-02-2025 11:24 AM
For the last week or so, my data has had periods (1-3 or 4 hours) of complete outage. Pages won't load, can't stream a song on spotify, can't even send an iMessage.
I've tried switching to LTE only, but no luck. Is there some reason for this? How do I make PM aware?
06-02-2025 01:22 PM
@slusagm wrote:@Chalupa_Batman I think that is for Bell home Internet , I am not aware Bell has a link to check mobile outage
Honestly @slusagm it's kind of hard to tell as it doesn't specify mobility or home internet. It does have a note there about power outages and reset your equipment but that could be just to cover their bases. 🙂
06-02-2025 01:19 PM - edited 06-02-2025 01:19 PM
06-02-2025 01:02 PM
@nicktubaro wrote:Yeah I'm assuming something is going on with the overall network here. My wife is having the same issue and we work somewhat far away so I think we'd be on separate towers.
Hey @nicktubaro
Port Arthur here.... kind of. 🙂
https://support.bell.ca/outage-check
You can check here if there are issues in certain areas with Bell.
06-02-2025 12:05 PM
06-02-2025 11:28 AM
could just be local network upsets or maybe networks outage for upgrades. Have you tried moving around to different areas to see if it still happens ?
06-02-2025 11:27 AM
hi @nicktubaro
I believe PM and Telus rely on Bell network in thunder bay, so it could be a Bell network issue
but check with PM support agent. Ask them to check or refresh your account. submit a ticket with PM agent and for reimbursement. You can submit ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
