04-13-2023 12:58 PM
Public mobile website in the past showed incoming calls whether answered or missed
Where do I find them?
04-17-2023 05:03 PM
Thank you for your reply.
I would prefer to see the number that called, rather than the voicemail number
Unfortunately, some callers do not leave voicemails. So the only number I see is the Voicemail number, not the originating number
04-13-2023 01:18 PM
HI @a8610 check usage history page.
and remember, those calls you missed got forwarded to the voicemail, show it will be showing as an call going to number ends with 4001
04-13-2023 01:11 PM
On a first page:
04-13-2023 12:59 PM
Login to My Account and check the Usage history page
https://selfserve.publicmobile.ca/en/account/plan/usage-details
do not use the filter there, it doesn't filter properly. If you need to filter, download the full log in XLS (download button on top right) and then filter yourself using Excel
