payment
Gopher1
I have been overcharged for the second time in 2 months
. please make a edit adjustment
laurabridgland
Did you check your account status? Did you confirm your plan? Have you checked your payment history?
HI @Gopher1   overcharged or duplicated charge?
2 months in a row?  did you do anything last month?
if you need PM agent to look into it, please submit ticket at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@Gopher1  can you give me details about how that happened?  Are you on the $55 plan with $20 discount? or different one?  Or how much overcharged?
just a reminder, PM will charge you tax on top of the plan price.  So, while a plan might show $25, PM will charge $25+tax on your credit card
