04-16-2024 06:21 PM - edited 04-16-2024 06:24 PM
I just got a new plan and ported my number. Everything seems to be working fine except imessage, which is just stuck on verifying my number. Because of this, I am unable to receive otp's and messages other than personal imessages to my email.
04-16-2024 06:26 PM
Thanks
04-16-2024 06:25 PM - edited 04-16-2024 06:26 PM
@Prats - iMessage is having difficulties with activation. PM "Sounds" to be working on a fix but in the meantime try doing this:
We are aware that some of you are currently unable to successfully use iMessage and or FaceTime features, and we understand how frustrating this can be. Our teams are working diligently to find the cause.
In the meantime, please try troubleshoot steps:
Tap Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings.
We apologize for any inconvenience this may have caused and will continue to keep you updated.
Thank you,
Also contact CS_Agent if SMS or MMS does not work:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work correctly, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. * CS_Agents are at load due to iMessage activation issues so it may take longer than 48 hours. * They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
04-16-2024 06:24 PM
HI @Prats
Yes, there is a texting problem with new account and affected iMessage activation.
Please ask PM agent to refresh your account. submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
