14 hours ago - last edited 2 hours ago by Dunkman
Hello,
I ported my number over last night, it’s been about 12 hours and I cannot receive SMS messages (I don’t receive 2FA messages) and my iMessage fails to verify my phone number. I reset my network settings, turned iMessage and FaceTime off and restarted my phone and turned both on again without any luck.
Does anyone have any suggestions? Did the port over fail?
2 hours ago
Not sure if you are still having issues. Are you able to receive phone calls?
If you are unable to receive phone call and unable to receive texts, then likely a porting issue. You should be able to call out and text out though.
13 hours ago
@Haziq Did you leave your old providers sim in the phone to reply YES to the confirmation text to port ? If you missed that step I’ll send you the porting team number they can re trigger the port request for you . If you didn’t miss that step it maybe just account setup issue in that case you can direct message support to help using this link
