06-13-2019 09:11 PM - edited 01-05-2022 08:03 AM
06-17-2019 11:05 AM
The microphone icon on the keyboard should not consume data if you're simply speaking to write the message. I use it frequently in Messages and Signal on my android device for this purpose.
If you're using an assistant such as Siri or the Android Assistant, chances are that it needs to go to the internet to get a response for you, before displaying.
06-14-2019 12:40 AM
@Winger19It depends on which app you are using for "voice input for text messages does this "incur" data use Mbs". Most phone OS has a feature that will limit data usage to cell phone or wifi for each individual apps.. it would probably be easier for you to use that feature for each of your apps to limit data usage.
06-13-2019 09:52 PM
Thank you
I keep turning off mobile data on an android device to conserve data... if I want to use voice input for text messages does this "incur" data use Mbs?
So to be conservative with data...probably leave mobile data on... but do not go on search pages or Google etc... emails come thru... texts with pics ....fine
06-13-2019 09:13 PM
