10-20-2019 11:24 PM - edited 01-05-2022 07:39 AM
10-21-2019 12:48 AM
@J-LIt is important to read the fine print. Some bonuses eg recent data bonuses requires you to stick to a plan with a minimum amount, if you change to a plan that is lower than that you will loose that particular reward.
Depending on the situation and also which reward. For loyalty (1 year +), referral and any amount your earn via community rewards they will stay with you for that month. However for autopay, when you change your plan, it get deferred for that month to until the next month, so the next month you will get 2xautopay. It is one strange quirk of the system.
10-20-2019 11:50 PM
If you do an immediate plan change, you get rewards for that month. Unless you run out of talk, text, data, always set change to happen during the renewal.
10-20-2019 11:30 PM
10-20-2019 11:28 PM
Rewards stay with you...long as your plan is active.
10-20-2019 11:28 PM
Rewards are tied to your account and not to your plan.
Therefore, you will continue to receive your reward after plan change.
