I added the amount due to my balance, but I am still in Plan Expired.
KUNMI
I forgot the due date. So my balance was not enough.
I added the amount due to my balance, but I am still in plan expired.
What shall I do?
gjona
Hello, I had the same problem.  Send an email to the moderator team and they will solve it.  I believe that there was a problem with the system.
Good luck
Gjona
geopublic
What shall I do?
@KUNMI  Login into your selfserve account and click on the Re-activate button. If that doesn't work you need to message the moderators.
fanfan
Hi, if your phone is still working and you are able to make calls then I think you are ok. The situation is common and typically occurs as per this other thread.
https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/Plan-Expired/m-p/317917/highl...
Lieux
What shall I do?
@gjona Both you can try to add 1$ more in your account sometimes it help to reactivate the service.
duffer900
@gjona wrote:
I have the same problem and need help solving it
What shall I do?
You can try the lost/stolen phone trick.  In your account, report your phone lost/stolen.  Logout.  Wait 5 minutes.  Login and report your phone found.  Re-boot phone.  This resets your SIM/account.
Moderator can be reached at
gjona
What shall I do?
