08-31-2023 02:29 PM
I currently have a $15 3G plan with multiple $1 rewards for autopayment, refer a friend and loyalty. I want to move up to the $25 3G plan without losing my $1 rewards - will these be grandfathered ? (don't want to change to the points rewards accidently).
I received an offer for "5GB of 3G speed data for only $25/month". If I select YES, will I automatically move to the $25/month 3G plan and keep my $1 loyalty points, AND have 5GB of data vs the regular 1GB of data that shows for the regular $25 plan.
Is the 5GB then included every month going forward, or only for a limited number of months?
Thanks
08-31-2023 03:48 PM
@smp999 There’s another one for Quebec only it seems being texted as well for 5GB for $20
08-31-2023 03:46 PM
So it's pretty much confirmed that there is now a $25 5GB plan that is available to certain existing customers. How is that even remotely fair to all of the other existing (and new) customers who don't seem to be eligible for this plan? How on earth did they think this would be a good campaign.
08-31-2023 02:32 PM
@Bee29 wrote:I currently have a $15 3G plan with multiple $1 rewards for autopayment, refer a friend and loyalty. I want to move up to the $25 3G plan without losing my $1 rewards - will these be grandfathered ? (don't want to change to the points rewards accidently).
Rewards are unaffected by plan changes. This is an actual plan chnage. Unfortunately, I have seen few details about this promotion.
08-31-2023 02:31 PM - edited 08-31-2023 02:31 PM
@Bee29 Yes your old rewards will stay the same I can confirm they’re tied to your account not you plan . I just switched plans myself and kept old rewards check it out
Add and yes it will be 5GB every 30 days
