12-16-2022 06:56 PM
Hello,
I got a Black Friday promotion - 20gb at 4g speed plan ($55) w/ $20 store credit for 15 months starting on Dec 14th. I should've been charged $37.29 w/ reward-autopay ($2) applied. However, I was charged $58.76 this month. And th promotion that I got is not showing up in my public mobile account.
Can you please get a refund of the overcharge?
12-17-2022 01:05 AM
try to login My Account using Incognito mode and check if you have a $20 sitting in Available Fund. It looks like PM could be charging you full amount first and deposit the $20 back as a credit in Available Fund after
12-17-2022 12:24 AM
Did you end up getting a refund for the over charge?
12-17-2022 12:21 AM
I have the same issue right now
12-16-2022 07:51 PM
That solved it! Thanks
12-16-2022 07:12 PM
@jhee0275 wrote:Oh, I see the $20 credit. However, my plan has not been changed to 20gb at 4g speed plan.
Try clearing your browser cache and history. Close browser and then open a new window in incognito. Chrome or edge browser works well.
12-16-2022 07:10 PM
12-16-2022 07:03 PM
Are you a current customer and did a plan change at renewal? If yes that promo was for new activations and doing a change at renewal for current customers did not work from what I have heard in this community. You may not be eligible for this promo. An agent will have to sort this out for you.
12-16-2022 06:58 PM
Please try to login to My Account using Private or Incognito mode. Check if you have a $20 Available Fund.
Also, check Payment history and see if PM credit you $20 after charging the full amount
if still not able to find the missing $20 , please open ticket with CS agent:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
