11-28-2022 11:12 PM
11-28-2022 11:14 PM - edited 11-28-2022 11:15 PM
Follow the arrows that @hairbag1 gave in his screenshot. Then you will be able to change plans. Select speed. Use the arrows til you hit the plan you want then change plan on renewal @Sevenn211
11-28-2022 11:13 PM
@Sevenn211 just login to My Account, Plan & Addons page, click Change my plan. Make sure you look under 4G speed plan tab
11-28-2022 11:13 PM - edited 11-28-2022 11:15 PM
added...
log in to your account / Plan and Add-ons /Change My Plan.. scroll down using the little arrow.
