12-27-2021 08:56 PM - edited 01-04-2022 04:46 AM
i bought the public mobile sim card for my grand daughters phone I went all through the set up and have paid and her phone is saying unregistered sim
12-27-2021 10:12 PM
@Hutchie : While you're waiting have you tried some of the suggestions?
12-27-2021 09:30 PM
not solved just waiting for customer service
12-27-2021 09:27 PM
@Hutchie wrote:how do i open a ticket?
@Hutchie if you've already tried swapping the SIM cards to see how they work in each other's devices, I would recommend doing the device check that @esjliv first mentioned.with your grandaughter's device.
Do that here:
https://www.devicecheck.ca/check-status-device-canada/
12-27-2021 09:13 PM
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by Submit a Ticket,
Good Luck....
12-27-2021 09:09 PM
@Hutchie - Customer Support is reached through submitting tickets, methods found here: https://www.publicmobile.ca/en/on/get-help/articles/contact-a-moderator
12-27-2021 09:08 PM
12-27-2021 09:08 PM
Have your granddaughter remove the sim and check the sim slot for any dirt and debris. Then reseat the sim and see if it sits a little loose in the sim tray. If so she can use a little paper shim or a little tape to secure it in the tray. Ensure no tape is in contact with metal conductive side of the sim card.
12-27-2021 09:04 PM
@softech wrote:@Hutchie Did you confirm PM charge your credit card?
Try to reseat the SIM one more time (power off, take it out for a minute, put it back in and power on)
If it still fails, no worry, it is likely a SIM provision issue, open ticket with PM and they can solve it quickly
Spoiler
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
Also did you request a port during the activation process. If yes, from what carrier?
12-27-2021 09:04 PM
@Hutchie wrote:i bought the public mobile sim card for my grand daughters phone I went all through the set up and have paid and her phone is saying unregistered sim
Did you reboot your phone after activation?
Also, perform a reset of the network settings.
Try the SIM into another phone to see if services work.
Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
12-27-2021 08:58 PM - edited 12-27-2021 08:58 PM
