08-16-2023 04:49 PM - last edited on 08-18-2023 08:50 AM by Dunkman
08-16-2023 05:04 PM - edited 08-16-2023 05:04 PM
You can download the TextNow app and pick a 2nd number and call for free to the USA or you can use WhatsApp but you need WiFi to make the calls.
08-16-2023 04:54 PM
If you go on your account in the subscription and add-on’s section you can add long distance calling minutes.
You can also do this with 611 if you know your pin.
08-16-2023 04:53 PM
You need to login to My Account and click Buy Add-on on the top right of the Overview page (or go to Subscription & Add-ons), then you can buy this particular add-on:
1000 U.S. Long Distance Minutes - $15.00 ** for calling all 50 states, plus Pureto Rico and the US Virgin Islands
You can also go with a free workaround: Download VoIP app TextNow and you can make free calls to US.
08-16-2023 04:52 PM - edited 08-16-2023 04:52 PM
@Hemin You need to buy US add on mins from your my account subscription / add on page to call the US or get a CAN /US plan would work too in the same subscription add on page of your my account
