I signed up for the 10GB/$29 upgrade plan, but what happens to my old rewards?
publicmobilecus
There's no details about what happens to my rewards plan. (e.g. "Loyalty", "Refer a friend"  ,"preauthorized payments" .    I do not want to change to the reward points system.
Thanks
Sansan
Please note that the Legacy Rewards are connected to your public mobile account and not the subscription or plan you have. Changing plans will not affect your monthly rewards.You will keep your monthly savings. As long as you didn't accept or switch your fine.
Chalupa_Batman
Hey @publicmobilecus
You can sign up for any plan you want. If you're on the Legacy Rewards program, only YOU can change it. So if it asks to change to the new rewards system, just say no.
Changing plans doesn't change the rewards system.
